Will the dazzle work on a AMD 1.4? I thinking of buying a new pc and looking at the AMD1.4 and would like to get the dazzle2
I don't think the problem with the Dazzle DVC2 is the processor, but rather the motherboard. I would check with some Dazzle users and find out what motherboards are working for them. In my experience, don't plan on any decent support from Dazzle after buying the product, so make sure you check around and find some systems that are successfully using it.
I'm succesfully using the Dazzle DVC II with an Asus A7V Motherboard and an Athlon 1.33 GHz processor with no problems. I run both WinXP and WinME and they both capture video fine.
From what Ive read, its the shitty VIA chipset coupled with AMD Athalon chips that normally have the problems.
Im running AMD-751 chipset with Athalon 800, guess Id be okay!
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 19:39 -
Will all amd quad cores work on a am2 socket? (no + just am2)
By yoda313 in forum ComputerReplies: 25Last Post: 15th Apr 2011, 18:30 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
AMD Phenom X4 9500 vs AMD Phenom II X3 710
By kenmo in forum ComputerReplies: 16Last Post: 1st Apr 2009, 21:03 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24
