    Oct 2002
    South Korea
    I have been using Snazzi III PCI (DVD edition) for a month, capturing with an application named Movie Mill (bundled with Snazzi). Output quality is good, but Movie Mill is very rigid, and allows to change very few parameters for capture.
    I tried to capture with other Applications such as Virtualdub, Premiere, DVD Movie Factory, but all of them tell me that the Capture Device has the wrong drivers, or that the Capture Device is not recognized.
    I would like to use the recommendations of your Capture Guides section to get good quality DVDs and SVCDs, but all of them refer to the applications referred above, and not to Movie Mill.
    Is there any way I can solve this problem? The Home Page of Snazzi does not help at all, and my Emails to them are regularly ignored.
    Thanks and regards
    M.
  2. No, you can't use any other software to capture from Snazzi cards...If it is good, why bother use anyother software?
    Oct 2002
    South Korea
    The reason is explained in my post: there a lot of nice guides in the VCDHELP site for other capture applications, but not for Movie Mill.
    Perhaps I should write one, once I have learned how to use it properly...
    Regards
    M.
