loveo,
how can I burd VCDs with WinOnCD 3.8PE build with VCD Toolkit?
When I do that, my DVD-player identify the tracks as audio.
Results 1 to 12 of 12
I have follow the step by step introduction from the
http://www.icdia.org/cdprosupport/vcd/vcd2x/vcd_burn.htm
site but if finish burning there was no directory at disc but the tracks are there.
Please help! -
I get no error messages, I've got only an emtpy directory.
No directory was created, but the tracks are on the disk!
When you say "empty" does that mean you have a readable root directory, or no directory?
RF -
When I look at VCD with WinOnCD there are the tracks I've burned.
And I think there was an empty directory because it says 0 Files and 0 Bytes. -
Download ISOBuster from http://www.isobuster.com and post what it says about your CD.
RF -
OK, I've done:
When I start the ISOBuster I get the following message:
Unknown File System:
The Primary Volume Descriptor is Unknown to the application.
Do you want isobuster to proceed in search for another supported File system?
So I've pressed YES and isobuster will go on:
It show me the following structure:
-CDRW
- Session_1
- Track 1
- Track 2
Problem solved!
Now I can finaly burn with winoncd.
My way to get success:
1) Bulid with vcd2tk1
2) add the -s in the *.msc file
3) rebuild with vcdmaster
4) use splitter
5) finaly burn with WinOnCD described at http://www.icdia.org/cdprosupport/index.html
My VCD runs well on PC and DVD-Player! -
Yes, you can also use the TOCSplit 1.1 utility. but the way you get success is a little bit diffrent:
1) Build with vcd2tk1
2) Use TOCSplit and Fix MSC
3) Rebiuld with vcd2tk1
4) Use TOCSplit Setup option: CUE/ Track files
5) Use WinOnCD:
a) Select only the created BIN files
b) Set track and file format discribed, but do not change the 'Start writing at block offset' field.
This way is much easier than useing splitter!
"Toolkit" for using a laptop to play video and audio onto a tv
By bobogs in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 20:49 -
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 10:15 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
