When i burn a dvd i first use dvddecryptor if the size is ok under 4.5 i use infoedit and then burn it as UDF 1.02 not video mode with nero. The dvd-r medium works both in my Sony 7700, Pioneer 535 and p.c The sames happens when i use infoedit and cut subttitles and languages. Plays good on both machines.
Last night i tried to cut using dvd2dvdr and cinema craft encoder 2.50 a movie that was bigger than 4.5 -The Others-. After the process its size became 4.30gb i burn it in the same way but now it works in my pc but does not work in my player do you know the reason ?
Thanks for your help.
I am looking forward hearing from you![]()
Your friend
Results 1 to 1 of 1
How do I compress a movie (12.5gb) w/o losing much quality?
By aple in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 10:39 -
VOB2MPG-PRO: Problem extracting VOBs from Verbatim DVD+R Dual Layer (8.5GB)
By rickyp513 in forum DVD RippingReplies: 1Last Post: 25th Aug 2010, 16:47 -
Problem writing on BD-R with a Lacie d2 Blu-ray burner
By L7dra7 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 21:03 -
DVD writing speed problem
By dmckay2007 in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 16:38 -
Problem writing to Philips dvd-r.
By jackrussell in forum MediaReplies: 0Last Post: 13th Jun 2007, 05:41
