Hey ppl,
I have a bit of a prob ripping my dvd's, i own pioneer dvr-104 and have ripped the spiderman movie VOB files using smart ripper. The combined total of all the vob files is close to 5 gig.
So basically i want to remove the director commentaries which i dont really want so that hopefully it will all fit on 1 DVD with no image quality loss. I have downloaded loads of software packages (ifo edit, REmpeg2, dvd2av, tmp, moviemaker). Can any1 tell me which software will let me do this and a guide on how to?Do i have to re-encode the full thing or something?
The movie is about 1 hour 56 minutes and i heard that 2 hours of video can be fitted to a dvd-r, so technically it should fit wont it ? i mean after the commentaries are removed?
Arghhhhhh help me please
Thanx,
Bob
can you rip blurays and then remove audio commentaries without reencoding?
By krohm in forum Blu-ray RippingReplies: 2Last Post: 1st Mar 2010, 08:54 -
Ripping Commentaries
By jmsajdak in forum Blu-ray RippingReplies: 2Last Post: 4th Sep 2008, 09:37 -
Director's Commentary
By budwzr in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2007, 22:19 -
director commentary.How do you avoid it?
By Dr.Gee in forum Newbie / General discussionsReplies: 6Last Post: 2nd Nov 2007, 09:43 -
Cyberlink Director
By micromack in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 16:38
