i converted and burnt a movie too svcd and when i went too watch it, it was upside down, i used nero too convert and burn, anybody know what i;m doing wrong ?.
It might've been that you burnt your SVCD at a very high speed. If you did burn your SVCD at a speed like 8X or so, lower it down to 4X or 2X and see if that helps.
:P
CD recording will not turn your picture upside down, at any speed. As I'm not familiar with Nero mpeg conversion, I can't tell you exactly what happened, but likely ther's an option somewhere that was responsible for the flip. If you can't find it, try other encoding software. How about DVD2SVCD? It's very easy to use. Or if you are starting w/ something other than a DVD, try TMPEG or Flask, or EO converter.
all are available from www.afterdawn.com
Vegas 8.0 - ITS UPSIDE DOWN!
By 1320Video in forum EditingReplies: 7Last Post: 17th May 2008, 12:35 -
upside down play back
By suomiaussie in forum Software PlayingReplies: 2Last Post: 14th May 2008, 13:22 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 07:13 -
My video is upside down
By Baldrick in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2007, 10:02 -
Upside down movie after the filmMachine
By Belfour in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2007, 06:29
