Hello,
I was wondering if I should do my SVCD in PAL or NTSC?
Is there a better quallty or are they equivalent?
Nas
You should use the correct format for your region
Practically speaking both PAL and NTSC or equal
some claim PAL has better colour and it's certainly easier to encode because you don't have to worry about telecining
also try not to transcode material from one format to another - this introduces quality loss -
North America uses NTSC. All of Europe uses PAL.
NTSC (VCD): 352x240/23.967 or 29.97Hz
PAL (VCD): 352x288/25Hz
NTSC (SVCD): 480x480/29.97Hz
PAL (SVCD): 480x576/25Hz
Apparently, most DVD players can work with both types. My Apex player seemed to have worked with a PAL file I downloaded...
But you definetly want to use the correct format.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
