I have a Sony PC120 DV Camcorder
The software it supplies captures to an AVI file in DV format of resolution 720x576
When i play this file in windows media player it shows a black bar to the left and right of the picture
Is it actually missing a bit of the picture or is it a squashed/streched image?
Using the DV software that came with the camera Ulead VideoStudio 5.0 DV it allows me to further compress the DV in AVI and MPEG (and probably other formats)
What i want to do is convert the DV formatted AVI file onto a DVD disc to play in a dvd player
Using NeroVision express if i use the DV format AVI file i get poor picture quality on the dvd, far worse then if i had just recorded it onto VHS
If i compress the DV using videostudio to an avi file compressed with divx first (and set the resolution to 640:480 which is 4:3) i get far better quality
But converting DV to divx and then from divx onto dvd is and incredibly slow process
On a 1min 30sec clip it takes about 5 mins to compress to divx and then 10 mins to transcode the divx file onto a dvd, imagine me trying to do this with a 2 hour recording, i would have to leave it all day!!!
Is there some good software that will convert the AVI file from DV format to MPEG2 DVD, it doesnt matter if its expensive, i want good quality![]()
Eric
Sometimes media player makes DV video look "odd". You may not have a problem. As far as software for converting, you could use 2 products from http://www.puremotion.com. Download the demo version of EditStudio, and mpegXS and give those a try. The editor has an easy to learn interface, and the mpegXS is based on the Main Concept mpeg encoder, which is quick and better quality than a lot of the other in-expensive encoders.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 14:30 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 12:25 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 08:21 -
Aspect Ratio
By kolias in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 09:28 -
aspect ratio help
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 14:41
