  1. got 2 bin's with the mpg files called: AVSEQ01.MPG.
    I extractesd them but cant play them Sound spikes and jumbled picture.
    I installed various mpeg2 codecs (the one on this site, one from Nimo, Elecard, etc) still same problem.
    Tried alo in mediaPLayer, PowerDVD, WinDVD same problems...
    Any ideas? How do I know which mpegs 2 codec the player actually uses when I double click the file to play?
    Thanks in advance.............
    I ate a grizzly bear for breakfast.
  2. btw...im getting what it seems others are calling the green screen problem .... though none of their remedies works here ...
  3. HI!
    I also have the green screen problem, still looking for a sollution please tell when you found a sollution, tnx
    just copying the AVSEQ01 file to your disk won't work for some reason
    but I found out that extracting it from the cd using isobuster/option "RAW" does work. ( there are two "+ expandables" I used the blue >>> one, not the ISO one)
    This also works from a bin file I persume.
    cya Ro
