i using TMPGEnc and i'm getting to the last screen so i can make my movie into an MPEG file, but, everytime i click "start"...it says "can't load P3Package.dll"...i then installed TMPGEnc again and unzipped all the files but this message is still coming up...any ideas why???
hi there youre answer is
Technical Question
Q. When I run TMPGEnc, it says "Can't find P3Package.dll".
A1. Downloading problem
If you have not downloaded correctly, this may be occur.
Please download it again. We recommend you to use Internet Explorer to download.
A2. Unzipping problem
If you are using older version of unzip program, it may ignore original file/folder structure, as a result, the dll is extracted to different location from original.
We recommend you to use latest version of unzip software.
i copied and pasted the answer for you -
okay, well i'm using something else to UNZIP the files but now it's saying "write error occured at address 77F536F7 of module 'ntdll.dll' with 00000000....anyone know what ANY of this means???
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 15:10 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
How to make audio file with subtitled file to iPod?
By nepenthesworld in forum MacReplies: 1Last Post: 7th May 2007, 11:50
