I have been ripping, converting, and burning DVDs/AVIs/XVCDs for years now, and this is the first time I have ever had seroius trouble that I cannot fix.
I downloaded a few movies, all of which use the "Lame MP3 Encoder (ACM)" and the audio will NOT convert. I have done everything I know how to do. Even when I have installed the decoder it just won't work (using TMPGEN, and every other program you can name).
If I just put it through, it does just video, with no audio. If I use virtual dub and just take out the audio, there is this horrific ticking noise in the background, and once I put that into the MPEG wherever there was that click, there is no noise, so the audio is shortened significantly.
I have no idea what else do to. Any help would be GREATLY appreciated. My e-mail is MSDGamer@aol.com. Thank you very much
Results 1 to 1 of 1
Installing 32bit AAC ACM and AC3 ACD codec on Windows 7
By pchan in forum Software PlayingReplies: 3Last Post: 26th Apr 2012, 15:53 -
Trouble installing AC3 ACM codec on 64 bit OS
By Teemo in forum AudioReplies: 0Last Post: 30th May 2011, 16:42 -
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 22:30 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 27th Jul 2007, 00:05 -
AC-3 ACM Codec na RMVB = PROBLEM
By krain_l in forum Authoring (DVD)Replies: 1Last Post: 16th Jun 2007, 18:48
