Ok now...
Where do i find a tool that can choop up mpegs in the same manner that avichop02 choops avis?
I have tryied SO many different tool and the one that comes closes is VCDcutter. The VCDcutter can automaticly cut a selected mpeg/mpg file into pieces, but all the pieces have a fixed size of 1Mb...sigh.. Some one help please??!
Best Regards Loki
NOTE: I know that fx TMPGEnc can choop files, but it cant do it automaticly.
Results 1 to 14 of 14
Somewhere under options in VCDCutter, there should be a place where you can change the size of the automatic cuts it does, so it won't just generate 1MB segments.
"M2 edit" is a very good program for cutting Mpeg files, its not free from the site, BUT
http://www.mediawaresolutions.com -
Hmm www.mediawaresolutions.com/ seems to be down. Any1 know another downloadplace?
Im sure the trial download will work, try again in a day or so. See if you like the program "Cyco.exe" hint
Nope the link is 100% dead - has been so for weeks (reconized that i had tryed downloading it before). Thanks for the advise none the less
- Loki - -
There is a VCDCutter that will work and my clipped clips are 30 megs and more. Send me a email and I will send it to you. Its version 402 and it's in a rar package 1.3 megs. It uses a CORE keygen. I used it with a xxx video that had a audio sync error and I broke it down into sections and used Total Recorder 32 to record the sound while the movie play and remixed the audio back to a decent video from mpeg to divx avi. Virtual Dub stopped mid way because of the error. email is ... m4mach10@pacbell.net
Hi
Just checked the download and its working, how many hops on your computer before your time to live is up
I think its M2 edit V4, looks the same as the one I downloaded before, but I guess there has been some changes. Its 17Mb or so, what download speed to you have ?
I have cable but i don't need it now - lacywest provided me with a working version of VCDcutter - Merci M8'
- Loki -
Notic: Just wanted to thank everybody that responded to this thread. I often find that people just dont care or simply dont give a *Biiip*
. So thanks!
Scene Detection and Cutter for MPEG File
By klode in forum EditingReplies: 6Last Post: 6th Nov 2011, 18:39 -
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
easy mpeg 1/2 cutter?
By ecc in forum EditingReplies: 2Last Post: 7th Oct 2007, 09:17
