I am putting together an SVCD that will use 30-40 different video clips, and some "photo slideshow" type mpeg files. I am looking for a program to use in adding transitions and such between the different clips.
Is there such a program out there? Roxio has "Video Impression" which is great, but only compatible with VCD, not SVCD. Nero doesn't have the option.
All help is appreciated, as we are putting together clips for Christmas presents. Thanks!
I recommend Adobe Premiere as it does mostly if not all the things you just posted.
Hope That Helps!!!
:P
transitions hard to add on multiple clips in premiere
By codemaster in forum EditingReplies: 11Last Post: 7th Jan 2011, 11:34 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 01:04 -
need player for demo clips - freeware, flexible and smooth transitions
By sybariten in forum Software PlayingReplies: 2Last Post: 9th Sep 2009, 19:23 -
Transitions between separate video clips ??!! no possibilities..
By Harviz in forum Authoring (DVD)Replies: 2Last Post: 30th Nov 2007, 09:04 -
Best program to add clips together?
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 02:47
