hey guys here is my delima
i have a sony dav-s300 great little sounding system and 5.1 also
ok i ordered some acu's off the net after reading alot of good post on them. only to come find out my convential method of aturhoring woulndt make them play on my sony stand alone or my ps2 but would on my apex and jvc and pioneer.so i tried sonic my dvd same results so i accepted that i would have to watch it in another unit and use sony for sound only but then about 20 disk into the spindle i had a disk error on the other dvd players with the 20th disk that i burnt said disk error on every dvd player except the sony which poliltely said "can not play this disk" i had already erased the encoded image and the divx from which it came so i thought maybe the dvd was bad so i copied it with dvd decryptor onto dvd-rw and it played. IN sony stand alone as well as the others.so i then took the same iso made by decryptor and burnt it to disk 21 of the spindle and low and behold it played in all of the units including the sony stand alone which hasnt read disk 1-19 of the spindle.
here is my dvd authoring steps :
1. Make mpeg 2 dvd complient with tmpgnc
2. open with ulead dvd movie factory and create vob folders
3. open nero 5.5.10.0 choose video dvd and drag folders over to template
4. then burn
5. i have also allowed ulead to burn instead of making the folders and using nero same results
ok engouh of that here is the question
if i burn the disk first then copy with decryptor it will play in the sony stand alone and all the others
dont want to double burn every disk so is there a way to go from mpg or vob to dvd with decryptor ??
plz help
