I've been messing around creating XVCDs using TMPGENC. I noticed recently that some of them have a slight shudder when encoding using bitrates above 1400.
Has anyone else experienced this problem. I've got a good player Pioneer 343 - I was led to believe that you could crank the bitrate all the way up to 2600 and still be able to play the XVCD on this player?
My other hunch is that this problem is being created when I use VCD cutter to cut the finished mpegs. Not really sure about this.
The bottom line is should I be bothering creating XVCDs at all and just stick to the standard 1150 VCD standard because there doesn't appear to be a huge difference in quality.
Alan
If you believe your DVD player supports higher bit rate, then no reason to stick to standard VCD. My Sony 660 plays VCD at 2600 kbps flawlessly (really superb quality when encoded from TMPGEnc).
Your VCDCutter could be a problem but you can verify that. Just encode 10 - 15 min clip and burn VCD (so no VCDCutting) and test. Otherwise, you may have to fiddle around with settings. -
cut with TMPGEnc, it does a better job than anything I've tried. If you have a Pioneer than make XVCD's. Use force film in DVD2AVI and your movies will play smoother. Use high quality slow for motion search
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 15:28 -
Problem creating burnt-in subs for other chapters with AutoGK
By Squirrel448 in forum SubtitleReplies: 5Last Post: 3rd Jan 2011, 18:07 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 15:16 -
problem with fairuse wizard creating project
By Wizard23 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 14:30 -
problem creating my own component cables.
By nick101181 in forum Newbie / General discussionsReplies: 10Last Post: 2nd Oct 2007, 13:13
