Hi There,
I've got big problems trying to convert my AVI-files to i/e Mpeg-1 files to be used for VCD.
When I try to open the AVI (I've tried several) I get the errormessage:
"Can not open or unsupportet"
All the avi-files in question play without trouble in Windows Media player. I've read all the "how to" manuals (i/e using LSX-MPEG Encoder 3.5 Demo) and tried to follow them step by step, but I keep getting errormessages.
Any ideas ?
Kind regards - Sogge
Thx - a lot - that solved the prob
I've been thinking if there's a possibility in i.e. TMPGEnc of "feeding" the batch convertion list via "drag and drop", instead of the the wizard that demands a repetative process if you want to convert say 50 files in the same way to i.e MPEG-1 ??Kind regards - Sogge
mpg editor to work with DVD styler?
By KaiserD2 in forum EditingReplies: 13Last Post: 20th Apr 2011, 16:29 -
having trouble getting avi to work
By Onceler2 in forum DVD RippingReplies: 5Last Post: 8th Aug 2009, 00:02 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35 -
Sony .MPG files don't work on Mac? Is that true? Can I convert them?
By zernalaw in forum MacReplies: 2Last Post: 30th Nov 2007, 14:15
