Hi there!
I just converted a DIVX movie to SVCD with TMPEGenc. But when I wanted to add a permanent subtitle to the movie virtualdub gives me an error that virtualdub doesn't read Mpeg2. I usally make vcd's and add a subtitle to it. That is no problem at all. Has anyone a tip or something so I can add a subtitle to it? Is there any filter for it or something? Thanks a lot Ba-2 8)
The time to add the permanent subtitles was when you were encoding with TMPG. To add them now would mean another encode.
A relatively easy way to get subtitles is to frameserve your DivX to TMPG with Virtualdub and use the Vobsub filter. -
All right thanks a lot. But when I tried to frameserve the avi with a subtitle filter to Tmpegenc, it gave me a error which said: "Illegal floating decimal point calculation order"!?
What should I do? Thanks a lot and cheers! Ba-2
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:16 -
Completely Useless with this ...Add intro to already made DVD
By stressbag in forum Newbie / General discussionsReplies: 6Last Post: 5th Feb 2010, 06:02 -
Hot to made larger letters in subtitle workshop
By MI6 in forum SubtitleReplies: 1Last Post: 13th Apr 2009, 06:44 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
question about how to add chapter points to already made DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 24th Apr 2008, 14:44
