Hi!
I didn't find an answer to my problem in the forum, but maybe some of you can help?
I want to author my home videos to DVDs with ac3 sound, but I am afraid of the consequences. If I wish to take one of those DVD and reauthor (cut out scenes) will that be possible?
I have already tried cutting with TMPGEnc but that gives me a new mpg with no sound.
Is there another program that will cut an mpg with ac3-sound or is there another way?
Please Help!!!!
And a merry Xmas to you all!
I was just checking the forum to find an answer to the same exact question.....I am going to try to cut the video with Tmpeg and then use headac3e to splice the ac3 and them put it back together with dos I think it will work...but headac3e does not let me get the audio onsynce with the video once i have edited it>>>
Anyone please help...I will let you know how it went anyway -
you can cut and splice ac3 and mpeg2 in vitec pro dvd tools ..
you have to do them seperate but you just go by the time code or frame count .. vitec pro can cut on I B or P frames or you can go to I frame only editing mode .. -
Thanks for the answer!
But where can I get vitec pro dvd tools?
I have never heard about before!
Is it expencive? -
Just what I was here for too. Home Video with AC3. I can split the wav out of the avi file and encode AC3 from the wav file, BUT now tring to figure how to put them together and burn it to play in set top in AC3 and not 2 channel.
I'll keep looking and let you know if I figure something out and if you would too?
Thanks Tim
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
Cut DVD movie, is update necessary?
By dexter30 in forum Authoring (DVD)Replies: 2Last Post: 2nd Sep 2011, 06:55 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Need Help with Movie Cut Short
By shalini72 in forum Newbie / General discussionsReplies: 7Last Post: 2nd May 2010, 01:02 -
How to Cut out a scene in a movie using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 07:49
