how do u make a vcd smaller or at least shrink in a little
well you could chop some off some of it or re-encode it at a lower bit rate
Use this guide Rizzo to lower the bitrate on your movie which will make the size smaller and fit in one CD:
http://www.vcdhelp.com/forum/userguides/84759.php -
The VCD bitrate for both Video&Audio&Padding combined is FIXED at 1411200 bps. Any lower bitrate will make an XVCD, i.e. a non-compliant some-sort-of-VCD that will work in some players but not in others. The capacity of standard VCD is limited to about 40 seconds less than the audio capacity of the CD.
Also TMPGenc will not give you truly VCD compliant MPEG-1 data with the VCD presets. Use 1-4-2 settings & no scene change detection in GOP options, and mux your Audio and Video with VCDMUX from the Philips VCD 2.0 toolkit (now freeware) if you want to be on the safe side.--
Linards -
It just get fucked up if you use the new version of TMPGEnc (v2.59).Originally Posted by tearex
Use the old one instead (v2.58 ) from here:
http://www.downseek.com/download/21222.asp
making mkv smaller
By jetli68 in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Sep 2011, 12:31 -
Making a 1 gig HD wmv file to smaller portions
By OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 12:10 -
making an avi file smaller to burn
By enigmatic620 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 09:29 -
Making file smaller in Adobe Premiere Pro
By JustinBaker in forum EditingReplies: 2Last Post: 18th Sep 2007, 16:07 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 04:23
