  1. Hi !
    I found a new fine tool !
    You can make a VIDEO_TS.IFO with it.
    Use rip, may rename and let the tool run.
    There you have a new Video-TS.ifo..
    It worked for me.
    Link: www.plenert.net , Klick "mydvdtool"
    CU !
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    V 00.00.0001ß is the version! ... doesnt give someone a warm fuzzy feeeling about using it , well i guess you could say at least its out of alpha stage..
  3. Yes, you are right ... .0001ß is not a very high version number ...
    But it worked for my perfectly.
    - I rip a dvd
    - Rename the move to VTS_01_... (if neccesarry)
    - Let it spit by ifo-edit
    - Execute "Get VTS Sectors"
    - and let the tool run on both discs
    It simply works, as well in version .0001ß !
    CU !
