I have an Pinnacle Studio PCTV capture card, and a problem...
With Windows 98SE i was using the 4.02 drivers, and capturing with virtualdub with this configurations (for VCD): 352x480 YUY2 / PCM 44hz 16bits Stéreo Audio with these realtime filters => Deinterlace, Resize 352x480 -> 352x240 and Noise Reduction. And them converting to VCD / xVCD with TMPGEnc. But when i installed Windows XP the drivers no longer function, huge frame loss... So i upgrade to the latest 5.xx drivers (that are WDM) and i cannot use VirtualDUB anymore... it says that it cannot capture to my device...
What can i do to fix this? Or what other program have those filters i was using with virtualdub?
By the way, i´m now using IuVCR, it´s great, but don´t have those filters... I can find those filters (deinterlace, resize, noise reduction) for IuVCR? And if i can, where?
Thanks to all!
Windows XP - SP1
ASUS A7V133 Motherboard
Atlhon 1.2ghz (C)
512mb PC133
Ati Radeon 8500 Retail
Creative Ensoniq AudioPCI (1371)
Realtek 8139 Lan
Lite-On DVD 16x
LG CDRW 16x10x40
