Results 1 to 14 of 14
    May 2002
    Holland
    Got a problem with avi file to svcd.
    TMPGenc says when i try to open the video source that it is unsupported.
    But i checked with g-spot and everything was installed.
    I tried to move up the priority of directshow, but when i right click on it it says that "the file cannot be loaded" is that my problem????
    I tried to follow the guide on this site but now i don't know anymore.
    Anyone does??
  2. Download Nimo Codec Pack:
    http://www.btinternet.com/~nimosiro/
    "Today is only yesterdays tomorrow"
    May 2002
    Holland
    i did already download it
  4. Paste the info from Virtualdub > File > File Info
    May 2002
    Holland
    how can i put the pic in this reply
  6. Originally Posted by meomy00
    On your keyboard press the Print Screen button.
    Then go to Notepad,Wordpad,Microsoft Word or whatever...right click on the open sheet and paste.
    Now save it and if you have a program like Irfanview you can crop it and resave the smaller section.
    If thats too much work,,,,then just go into Virtualdub File Information and manually copy the info.
    May 2002
    Holland
    Ok,
    I knew that but the paste is not highlighted when i want to put it i this reply.
    Manually then,
    Video stream
    Frame size: 352x288, 12.500 fps
    # of frames: 58264 (1:17:41)
    Decompressor DivX Codex 4.12
    Number of key frames 467
    Min/avg/max/total key frame size: 1452/8216/36466 (3748K)
    Min/avg/max/total delta frame size: 0/3013/22220 (170067K)
    Audio stream
    Sampling rate: 24000Hz
    Channels 2 (Stereo)
    Sample precision 0 bit
    Compression: Fraunhofer IIS MPEG Layer-3 codec
    Preload skew: 3232 smaples (0.13s)
    # of frames: 57785
    Min/avg/max/total frame size: 421/560/3232 (31605K)
  8. Ok..it seems that your FPS is only 12.5fps...
    so I don't think TMPGE can't recognize that.
    I does rhowever recognize 12 fps (internally 24).
    So,you may want to try using Virtualdub to change the framerate.
    File > Open Movie > Video > Full Processing Mode > Video > Frame Rate > Change to > type in 12 (and also check "Change So Video Audio match"...etc)> Video > Compression > Divx-mpeg4 - Low Motion > Audio > Direct Stream Copy > File > Save As AVI.
    I'm also a bit suspicious about the audio sampling (24,000)because I think TMPGE only recoginizes 3 different audio rates (32,000,44100,48000).
    You may have to try and use Virtualdub to convert the audio by:
    Audio > Full Processing > Conversion > check 44100 if you are making a VCD)....Maybe you can try this instead of previous suggestion of Audio > Direct Stream Copy.
    I can't guarantee that this will work ,but give it a try.
    May 2002
    Holland
    tnx
    i think it's working
    now i'm going to follow the guide further.
    May 2002
    Holland
    next problem,
    got 2 part now and i wanted to paste them,
    Virtual Dub comes up with this message:
    The video streams have different data formats
  11. The 2 parts have to be identical in compression,bitrate,etc,etc before you can append them in Virtualdub.
    May 2002
    Holland
    but i got 2 the same files "i think"
    here comes the info of file 1:
    Video stream
    Frame size: 352x288, 12.000 fps
    # of frames: 58264 (1:20:55)
    Number of key frames 373
    Min/avg/max/total key frame size: 2568/12737/27936 (4640K)
    Min/avg/max/total delta frame size: 58/6912/30677 (390766K)
    Audio stream
    Sampling rate: 44100Hz
    Channels 2 (Stereo)
    Sample precision 16 bit
    Compression: PCM
    Preload skew: 22050 samples
    # of frames: 55475
    Min/avg/max/total frame size: 5172/14701/88200 (796429K)
    here comes the info of file 2:
    Video stream
    # of frames: 65443 (1:30:53)
    Number of key frames 290
    Min/avg/max/total key frame size: 2427/11790/25432 (3340K)
    Min/avg/max/total delta frame size: 50/5057/29896 (322916K)
    Audio stream
    Channels 2 (Stereo)
    Compression: PCM
    # of frames: 52402
    Min/avg/max/total frame size: 14080/14701/88200 (752324K)
    [/b]
  13. In Virtualdub did you:
    Open Movie File #1 > Video > Direct Stream Copy > Audio > Direct Stream Copy > File > Append AVI Segment > Movie File #2 > File > Save As AVI.
    I'm assuming you want to join them (when you say paste?).
    If the files have identical specs (other than length etc) the it should work.
    May 2002
    Holland
    i did what you said, but the same result now.
    I'm going tot try it with an other program now. Maybe that works.
