I noticed under the "UDF" tab in Nero, one can select different file system modes, specifically: UDF 1.02, UDF 1.50, and UDF 2.01. The default is UDF 1.02.
Anyone know what the different modes do and what the implications are for set-top DVD players?
http://encoding.n3.net <-- for all your DVD and CD backup needs!
It appears that you should select 1.02 to remain compatible with the widest range of players. If you are burning only for yourself try all three on a DVD-RW and select the one that works best for you although there should be little or no difference in performance.
Panasonic DMR-ES45VS, keep those discs a burnin' -
the only time i could ever see using UDF 2.01 is for burning a DATA file over 4 gig size (for a single file) as i couldnt burn it any other way ..
I assumed 1.02 would give the widest range of compatibility; however, I would like to read about the differences between the formats. Anyone have a URL?
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
