I have an ogg/ogm (whatever it was) movie that I'm trying to convert (using tmpgenc) so I can burn it onto an svcd.
The problem is the subs, when I play the ogg on my comp they show up just fine (they're muxed in or something like that) but when I convert it they don't show up. What do I do?
Do you have your Subtitles positioned right ?
Are you adding permanent subtitle..?
If so can you see them on your PC...?
Are you creating selectable subtitle...?
Does your DVD Player support Selectable Subtitles...?
If it does are they CVD or SVCD Selectable Subtitles...?
How are you muxing your Subtitles...?
What are your using to mux your subtitle...?
Any guides you might be using..?
Elaboration would be a good Idea, or maybe even the search function.
Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
https://www.videohelp.com/forum/userguides/170944.php
How to encode DV to .ogg?
By macphoto in forum ffmpegX general discussionReplies: 1Last Post: 30th Jan 2011, 05:33 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
ogg's framerate
By zoobie in forum Video ConversionReplies: 4Last Post: 17th Aug 2008, 20:36 -
problem with ogg filters
By mehdi0016 in forum Newbie / General discussionsReplies: 2Last Post: 8th Jan 2008, 10:46 -
ogg codec
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 21:22
