  1. I have 3 svcd files and want to join them together so i can burn the joined file to dvd I tried TMPGEnc but got sync problems when the files merge i am sure someone will help me with.
    Derek
  2. Try DV-Tool - it's mpeg aware so it should be fine for sync (works for me anyhow).
    http://www.musclesoft.de/combatman/start.php?page=software/dvtool.html&lang=e
  3. del3165 that link is the one for you .i was having trouble then saw this post .all i can say is thanks alot to you phishwak for the link
    there can only be one:but its not me
  4. Thanks phishwak
    That worked great. Only problem i have now is that when the 3 svcds are joined i can not move to the end of the movie with power player so it seems that when i try and convert the merged file so i can copy to a dvd-r the end is missing the merged file is 2.3gb. My hd is partition is ntfs. I think it is the size of the file that is the problem is there a way round this.
    Derek
  5. bump.....
    DV tool doent seem to join my correctly, as soon as it gets past the merge oint it stops and wont play any of the second half of the file
