I am using DVDit PE for the first time and I was wondering if anybody could tell me how long it will take to create the DVD folder. I am using a 4.7gig DVD.
Is Nero the best option to then burn the DVD folder.
Thanx
it takes one hour and half to create a project in DVDit but i don't understand what you mean: i have a 4.7 gb dvd ?? a dvd5 ou dvd9 (stands for 9gb) ??
Thanks for the info.
i ment the drive capacity is 4.7gig.
When I have tried to use DVDit and I have to have the video quality low or it says it is to big to fit and when I start the create the folder it stays on the firt bar for well over half an hour. Is this correct? -
DVDit insists on converting the audio to PCM which is uncompressed and so takes up LOADS of space. One hour of audio is about 650 Mb. I suggest you find an authoring package that supports mp2 audio (if your DVD player will play it, some US ones don't I believe), or Ac3, as all DVD players will handle this.Originally Posted by fmb2000
...I thought DVDit PE supports AC3 (by looking at her comparison specs), I just don't know if it has her own AC3 encoder (I don't remember if it was mentioned, I would assume it does). Maybe fmb2000 has this setup to PCM...Originally Posted by bugster
jtor wrote:
You are right, I missed it was PE. It does support AC3 but it actually defaults to PCM, you must set it to use AC3 in the options somewhere. It only supports 2 channel AC3, not 5.1 and it does include its own encoder for converting Stereo PCM to 2 chan AC3. I gave up using it after it gave me sync problems....I thought DVDit PE supports AC3 (by looking at her comparison specs), I just don't know if it has her own AC3 encoder (I don't remember if it was mentioned, I would assume it does). Maybe fmb2000 has this setup to PCM...
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 14:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 12:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 23:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 02:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 01:51
