How do you do it?
A little more information about what you are intending to do would be helpful. eg frameserving what to what, and why?
You don't frameserve FROM TMPGEnc, you frameserve TO it.
Usually, you can use Vdub, DVD2AVI, AVISynth, or other VFAPI frameserving proggies.
The only thing TMPGEnc "frameserves" to is audio--LAME, TooLAME, and SSRC-type stuff. And that's really a external pipe with temp results being returned for final encoding and/or muxing.
<--- Read the How to's on the LEFT! It's all there.
Scott -
You can frameserve to it, or from it (by creating a project file .tpr). Although not strictly frameserving.
tpr project files are good for re-encoding of projects, or for use in batch encoding, but AFAIK they don't frameserve to anything.
While strictly not frameserving (as I already pointed out) TMPG can be used as an intermediary step in passing parameters in an encoding job. Sometimes this is referred to as frameserving.
However, unless and until the original poster shows enough interest to get back and explain exactly what s/he is intending, we are arguing about semantics.
Procedure:
1. Do what you need to do in Tmpgenc (e.g., IVTC, clip frame, choose correct output ratio aspect, etc.)
2. Save Project in Tmpgenc (file saved as *.tpr)
3. Open *.tpr with VFAPIConv and convert to *.avi.
4. Open *.avi with VirtualDub (for more filtering) or CCE (for encoding)
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
colors shift when frameserving from Vegas
By crisciunas in forum Video ConversionReplies: 7Last Post: 16th Oct 2009, 16:24 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
