hi...first post and all that...i've just upgraded my system with the hope my encoding speeds from divx/avi to vcd/svcd would greatly improve...although they haven't improved that much...anyone have any idea's?...help would be greatly appreciated...it's taking about 10-12 hours to convert a 700Mb divx/avi 1.5 to 2 hour film to VCD with TMPEnc if i'm lucky...i've read on this forum people converting to SVCD in a couple of hours...hope you can help...
are you using tmpeg to encode or cce?
and what settings do you use
these make a world of difference when it comes to encoding time -
hi...i use tmpeg and usually use keep aspect ratio full screen in the clip frame...high quality in noise reduction...and high quality in motion search precision...
thanks...what would you recommend...is cce any better -
those high quality settings are what slows it down
most people dont use such good settings
I on the otherhand dont use tmpeg anymore
CCE rocks and is soooo much faster!
not only that but the quality is superior
[FFmpeg] Up encoding speed for wmv's
By Klagar in forum Video ConversionReplies: 5Last Post: 24th Jan 2011, 13:00 -
Video encoding speed slower than previously
By genak in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 17:23 -
decreasing encoding speed with mencoder (mplayer)
By sammy82 in forum Video ConversionReplies: 2Last Post: 1st Apr 2010, 23:58 -
can you speed up encoding with ripbot x264
By zerocoool in forum Video ConversionReplies: 6Last Post: 26th May 2008, 21:07 -
Increasing Encoding Speed?? What Hardware makes it run faster?
By sandman423 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2008, 22:09
