  1. New how to get there in 98. Running xp and can't seem to find it. Anyone.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    right click on "my computer" -> manage -> devices -> to the hardware you want to manage
  3. hm... I guess my hp cd writer has no dma setting. Wierd.
    Jul 2001
    Maryland
    In Windows XP, DMA is not set at the drive menu.
    Go to the device manager then go to "Ide ATA/ATAPI Controllers" then you'll see your master IDE bus controler and two IDE channels.
    go to advanced settings and for everyone that has "auto detect" grayed out, make sure it says "DMA if avalible."
  5. That's the stuff. thanks.
