I have followed the steps on what to do to create a vcd BIN from an mpeg at http://www.vcdhelp.com/vcdimagergui.htm
I get the program up, select the mpeg file and where i wish to save the BIN click MAKE BIN and i get the following message:
Assertion failed: CreateProcess(0, argv.c_str(), 0, 0,TRUE, 0, O, O, &si, &pi) file D:\My Documents\vcdimagergui\thread.cpp, line 93
click OK then this message pops up:
Abnormal program termination
Anyone know what I've done wrong or how to fix this problem?
I thought i'd add that my D:\ is my CD-Rom drive (so I'm not sure what that has to do with the above error message.)
If anyone can help me out I'd really, really appreciate it.
Thanx in advance...
Baz.
I'm not really sure about your problem but try and change the output dir for the BIN to C:\ (Or whatever you HDD is)
This should fix the problem.
The problem probably came up because that VCDImager tried to create a file on a CD-ROM (Or on the empty drive
Just try my tip
Magnus Jensen
A.K.A Geezus -
Krusken:
I didn't type in D:/, i typed in C (HDD).
It just don't seem to wanna work for me along with all the other dozen programs i've d/loaded. But never give up sounds good, but it's a pain in the ass going around in circles with no answers.
Anyway, thanx for your input
<font size=-1>[ This Message was edited by: -baz on 2001-08-28 00:48:45 ]</font>
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
