Using virtualdub I have extracted the audio to a wav file
then using TMPGenc imported the audio with the video file
and throughout the preview and completion I have no sound
I've tried every everything no luck.
When I open the saved wav file it does work
Any suggetions?
THanks
Do you have the codecs?Do you have Nimo Pack,if you have not Nimo then you can install it from here:
http://www.btinternet.com/~nimosiro/ -
Mayby this gide will help you:
http://www.vcdhelp.com/forum/userguides/91588.php
Tell me if it works! -
don't know if this will help or not... but in virtual dub make sure that you check full processing mode for the audio... the wave should be about 1 gb for a 2hr movie or thereabout
You win some, and you lose some, and some get rained out...
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
Virtualdub and sound problem
By Shabaman in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 08:55 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
