Ive seen a lot of posts about DVD-R, but I just bought a DVD burner, the HP200i, and its a +R only. Did I make a big mistake? I thought +R was supposed to be the new format.
I have some DVD's I'd like to copy to a DVD+R, what programs do you recommend? I managed to rip one, with DVDDecrypter, and now Im confused as to how to make it an image or just directly burn it. Ohh, and the image is smaller than 4.7 GB.
Any help
You need to do A LOT of reading in the HOW TO section for starters.Originally Posted by skypine27
If your DVD is 4.37GB or less it is a DVD-5 and it is very easy to copy using DVD Decrypter doing the following:
1. Open DVD Decrypter and select MODE ISO
2. ISO READ
3. ISO WRITE -
Good guides can be found at doom9.org or try mine encoding.n3.net
http://encoding.n3.net <-- for all your DVD and CD backup needs!
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
