Everytime I try to load a .avi or .mpg video file in TMPGEnc, I get the error that the file can not open or is unsupported. Is there some settings or plug-ins I need for it to work? What is the problem?
Have you tried change the direcshow priority?
www.vcdhelp.com/tmpgenc#problems -
I downloaded the trial version of TMPGEncv2.59 to help with the backing up of my DVD movies. I uesd DVD2API to create a *.d2v file and an *.ac3, but TMPGE keeps telling me that the files are unsupported. I have tried many uninstalls and reinstalls to no avail. I have also tried setting the Directshow priority to 1 and even manually pasted the DVD2AVI.vpf file into TMPGEnc's file but even that didn't work. I'm at my wits end here. What gives?
The .d2v file should load into TMPG provided you have the right priority set. However, if you are creating mpeg2, then TMPG will not work if the trial perood has expired!
If you choose to decode rather than demux in DVD2AVI (remembering to re-sample) you can produce a .wav rather than .ac3, which you will have more luck with loading into TMPG.
Black Bar problems with TMPGEnc
By ereiamjh in forum Video ConversionReplies: 5Last Post: 22nd Mar 2010, 11:32 -
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 13:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
