My New dvd player (d21/3 gradiente) recognize all my vcds like mp3 cds, and dont play nothiingat all, i think its because of the folders, cause the mp3 can be organized in folders, so the dvd thinks that there are mp3 inside that folders. There is a way to make a vcd without folders, or a instruction to put on the cd to the dvd read directly the DAT file of the cd??
I thought that this might be the problem, any suggestion ??
Thank you
Why not burn an ISO CD-R and check, if the .dat files are played off root directory of the CD. If not, your player is incompatible.
.a -
Hey A, thanks man, my dvd its compatible vith vcd, it worked with "official" vcd but the ones that i amde he just recognise it like mp3..really dont lnow why, I use luead dvd movie factory to make the vcd, to do what u said, i must create a iso with ulead and then burnt it with nero??
Thanks in advance -
jhonnyad.. Are they all VCD or SVCD?
My dvd player is an Akai DVPS-760, and the folders you are talking about sounds exactly like what mine displays when I put in a SVCD.. it just wont play them unless I use the "vcd header trick" prior to burning. - then they play just fine. -
end80 yes they are all vcd and svcd and they work fine in other dvd players, this new model runs mp3 too, and now has this damn problem, i dont know why the player recognise vcd as a mp3 cd, have no ideia, does anybody knows??
Organizing project folders
By weskennison in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2011, 16:29 -
exact copy with more than 2 folders ?
By takenotes in forum MacReplies: 3Last Post: 27th Oct 2010, 20:19 -
Question on authoring with sub folders?
By npereira in forum Authoring (DVD)Replies: 5Last Post: 9th Jun 2009, 22:56 -
Folders keep shutting down?
By aelfheah in forum Newbie / General discussionsReplies: 12Last Post: 26th Feb 2008, 14:07 -
Add folders to DVD
By marioval in forum Authoring (DVD)Replies: 1Last Post: 2nd Nov 2007, 17:45
