Hello again.
I have an XviD file that only plays in WMP with extreme blockiness. Not sure what details I need to give you but is there a way I can get rid of this problem?, is it a codec issue?. The file in question (8 legged freaks) seems to be OK on other machines cos' I've asked.
I have V Dub and TMPG Enc' installed.
I know you will need more details so please don't shout at me![]()
I eventually want to encode this file to play on my standalone.
Thx
Results 1 to 9 of 9
I tried installing but got an error. 'Cant write/Windows/system/XviDdll'
Doh!. Should I be able to install a codec and that would enable me to play the file properly?.
Thx for reply -
Nothing.......just play your XviD file to see if you're still having the same problem.
I'm afraid I am. I notice that If I load it into V Dub it appears fine!. Any thoughts?.
Thx -
i had a simalar problem recently where i was also getting a green screen.
try this: http://www.divx-digest.com/software/ffdshow.html -
OK, sorry for the delay in getting back to you all, Xmas an' all.
I tried everything suggested and no luck. That codec from you tenders, I thought was going to do it but WMP eventually gave up trying to open it. I then had trouble playing some other movies so I had to un-install it.
I've since D/L'd another XviD movie as an experiment and am having the same problems.
Is there anything else to try?? -
Wahay :P
I D/L'd this
http://www.divx-digest.com/software/avifourcc.html
Changed my file to DivX and it now plays perfectly.
Hope this helps everyone else who has had this problem
green, blocky, XviD........(for future searches)
Thx for your help PPL
MPCHC playing xvid jerky in win7
By johns0 in forum ComputerReplies: 2Last Post: 8th Jun 2010, 05:05 -
Problem playing xvid on Vista
By Murimons in forum Software PlayingReplies: 6Last Post: 20th Aug 2009, 07:26 -
Lag when playing a xvid straight on my LCD TV
By Burner72 in forum Newbie / General discussionsReplies: 12Last Post: 19th Aug 2009, 10:47 -
xvid avi problem when playing on eternal dvd player
By myname77 in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 10:26 -
artifacts while playing xvid files
By greendesert in forum Software PlayingReplies: 2Last Post: 3rd Jan 2008, 11:42
