  1. Hi
    I have a really big problem... I got a DivX movie i want to cut in 2 parts and later convert it to SVCD. After i have cut'ed the DivX and then play the new files i get sync problems for the sound. The sound is several seconds ahead of the picture This seems to happen when i convert the audio to "No Compression PCM".
    Iuse DVD2SVCD to make my SVCD's from DivX. Tried that program 2 times now with audio sync problems Seems that this file doesn't want to be converted to PCM Audio. What should i do? What can i do to fix this problem?
    Thanks in advance...
  2. Try converting your movie to svcd first and then cut it. Might do the trick.
    J
  3. Actually the completed SVCD also have sync problems So the problem is in an early state
