  1. I'm trying to convert an avi using dvd2svcd and have come across a message on opening cce.
    Frame size 956 x56 is not supported.Supported frame size is up to 720 x576.
    I'm using the same settings for which I've had a few successess.
    avi details
    image width 640
    height 272
    Audio duration 01:35:08
    bit rate 312kbps
    audio format mpeg layer-3
    Video frame rate 23fr/sec
    data rate 118kbps
    video sample rate 24 bit
    video compression XVID
    LOG
    21/12/2002 13:26:58
    - AVI to SVCD Conversion
    - AVI2SVCD ver. 1.0.9 build 3
    Initializing
    Initializing finished.
    - 21/12/2002 13:27:01
    - Free on drive C: 7299.09 mb
    - AUDIO Extraction
    Audio extraction finished.
    - 21/12/2002 13:27:39
    - Free on drive C: 7103.84 mb
    - AUDIO conversion
    Converting MP2 to WAV. Filename: C:\Documents and Settings\steve\Desktop\movie conversion 2\Extracted_audio_1.mpa
    Executing MADPlay (mp2 to wav). Commandline:
    "C:\Program Files\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"C:\Documents and Settings\steve\Desktop\movie conversion 2\Encoded_audio_1.mp2.wav" "C:\Documents and Settings\steve\Desktop\movie conversion 2\Extracted_audio_1.mpa"
    Conversion (mp2 to wav) of C:\Documents and Settings\steve\Desktop\movie conversion 2\Extracted_audio_1.mpa finished.
    Converting Audio to MP2. Filename: C:\Documents and Settings\steve\Desktop\movie conversion 2\Extracted_audio_1.mpa
    Executing BeSweet. Commandline:
    "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Documents and Settings\steve\Desktop\movie conversion 2\Encoded_audio_1.mp2.wav" -output "C:\DOCUME~1\steve\Desktop\MOVIEC~1\Encoded_audio_ 1.mp2" -logfile "C:\DOCUME~1\steve\Desktop\MOVIEC~1\Encoded_audio_ 1.log" ) -ota( -g max ) -2lame( -e -b 160 -m s )
    Audio conversion of C:\Documents and Settings\steve\Desktop\movie conversion 2\Extracted_audio_1.mpa finished.
    Audio conversion finished.
    - 21/12/2002 13:36:25
    - Free on drive C: 6122.56 mb
    - Converting Pictures
    Converting: C:\Program Files\DVD2SVCD\DefaultTitlepicture.bmp
    Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp
    Finished converting pictures
    - 21/12/2002 13:36:37
    - Free on drive C: 6121.60 mb
    - Video Encoding using Cinema Craft
    Executing Cinema Craft Encoder.
    StreamSectors: 832542788
    AudioSectors: 104580
    VideoPAPO: 12894912
    ScanOffsetBytes: 2
    SeqAligningBytes: 153
    DVDBytes: 0
    VideoEndHeader: 4
    SubtitleSectors: 0
    EmptySectors: 238.00
    PictureSectors: 600.00
    PureMPEGStream: 819543137.07
    Seconds: 5.07
    CalcMPEGStream: 819543137.07
    Frames: 2
    CDSize: 800.00
    Cut point 795.00
    Variable Settings:
    Frames: 2
    Anti Noise Filter: Off
    Passes: 3
    Image Quality: 17
    VAF file creation: On
    Video Encoding Mode: Multipass VBR
    Min. bitrate: 300
    Max. bitrate: 2530
    Avg. Bitrate: 2230
    Aspect Ratio: 4:3 (No borders, encoded as 4:3)
    _____ALSO TRIED 16:9 borders added ,encoded as 4:3
    ---AVS Begin---
    LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec .dll")
    AVISource("C:\DOCUME~1\steve\Desktop\evelyn.avi")
    ConvertToYUY2()
    BicubicResize(480,368,0,0.75)
    Sharpen(0.4)
    AddBorders(0,56,0,56)
    ResampleAudio(44100)
    ----AVS End----
    Message then appears , any ideas? I've also tried converting using tmpgenc but lips are hopelessy out of synch
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    same problem exactly was posted in this thread below - so some bug i guess ---
    read this thread
    http://www.vcdhelp.com/forum/viewtopic.php?t=130526&highlight=
