  1. I've got an MPEG-2 file (SVCD) which is about 2.5gigs and I want to cut it down to fit on 3CD's (80mins). Where do I start? I've got TMPGEnc and VDub.
    Thanks in advance!
    Mar 2002
    United States of America
    You would use TMPGEnc for MPEG-2 cutting. Also, why is your SVCD coming out to 2.5 Gigs?
    Hope That Helps!!! :P
  3. Because it was two DivX files, which both came out at over 1gig each when I converted them to SVCD. I joined them both together, leaving me with a large file. Problem is, if I cut them they are going to have to be put onto four CDs because the file is so big.
    I only really want to put them on 3!
    MO, US
    If it's 2.5GB 3 80-minute CDs just isn't enough space. You can either cut out content (credits, introduction, a scene you don't like), or reencode at a lower bitrate.
    I'd also suggest bbmpeg for SVCD cutting, it's a little more work because you have to demux the MPG but most people agree that it does a better job.
    Mar 2002
    ben.franklin, you could also buy some 90/99 minute CD-R's and divide your 2.5 Gig SVCD over 3 90/99 minute CD-R's.
