I have two cd's containing a divx movie both under 700 mb
they play fine in divx player
I wanted to convert to dvd(one if possible)
so, I ran TMPGenc and converted the first cd to dvd(mpeg2)
the runtime after the conversion is 3 hours though the actual movie is
1hr and 15 minutes. totally confused it will just sit there and run till the 3 hours is up with no sound
Skinny,
Can I convert and merge both cd's together to make one dvd?
And what can I do about the no sound problem?
And is it normal to go from 700 mb to 3.5 gb when I run TMPGenc to encode? Otherwise I would need two dvd's for this conversion?
Is this the norm?
Thanks. Mike
I think you need to start reading some of the guides and other info this site has to offer. If you look over to the left column under HOWTO you will see a convert section. In there you will find several guides on converting divx to various mpeg formats. If you look a little harder you will also find information on how to handle 'missing' audio like you described plus loads of other useful info.
If you try any of the guides you find and still have problems the do come back and ask specific questions with as much detail as to what you are trying to do and where things have gone wrong as you can. -
well if i was you i would rent the dvd and encode it that way since you are trying to do that anyways. plus the quality will come out better. you said the movie is only 75 minutes so you will prob be able to copy it with out encoding........
Yes you should use the guides to convert. Basically you should separate the audio out to WAV with Virtualdub then encode the video with the WAV file you extracted.
Panasonic DMR-ES45VS, keep those discs a burnin' -
You can try this....
http://www.vcdhelp.com/forum/viewtopic.php?t=124811&highlight=
It worked for me. (read end too)
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Ire, still confused.
By aebbeka in forum Capturing and VCRReplies: 15Last Post: 25th Mar 2008, 06:25 -
resizing, I'm confused!!!
By nalooti in forum Video ConversionReplies: 5Last Post: 19th Nov 2007, 09:14 -
Confused about subtitles.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 03:38 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 13:42
