Results 1 to 14 of 14
  1. I have the DIVX version 5.0.2. I can't WATCH some movie and I want to know why. I right click on the movie that I downloaded, scroll down and click on PROPERTIES, than I click on SUMMARY, and I saw that the movies im able to watch are "VIDEO COMPRESSION MS-MPEG4 V3". The one I can't watch are "VIDEO COMPRESSION DIVX CODEC"
    Question? What do I need to download (codec) or need to do to watch the movies that are Video Compression "DIVX CODEC"
  2. CAN ANYBODY HELP?? SO FAR 24 PEOPLE READ MY POST AND NO REPLY. PLEASE HELP!!
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    well the standard answer is "install the nemo codec pack"
    and don't "bump" your posts ... this isnt a irc channel
  4. BJ_M, Do you mean "NIMO Codec Park"? I couldn"t find "nemo codec pack. Also, thanks for answering my question.
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes - sorry ..
  6. Bj_M or anybody, I downloaded Nimo, however it doesn't work. I mean, I still can't watch DIXV CODEC movies.
    Is there something Im not doing?
    Can someone walk me throught it?
    Talk to me experts.
  7. Banned
    Dec 2002
    Somewhere I belong
    Use a little program called GSpot which tells you which codecs the movie is in and if you have installed it.You can get it from here:
    http://www.headbands.com/gspot/
  8. Crack_man, thx for the software. It works great. What Gshot is telling me is that I need the Copec DX50/divx name Divx5.0.
    The problem is that I have DIVX 5.0.2 http://www.divx.com/divx/index.php
    Is this the same what they are asking for?? HELP
  9. Member vhelp's Avatar
    Mar 2001
    New York
    jtquest,
    How are you bringing in the divX clip ??
    ie, are you:
    * What app is telling you these errors ??
    * using a divX player ?? if so, whats' the app you're using ??
    * else, R U using vdub, but it's telling you it can't load it ??
    I would at least try and open them in vdub, as it will open these files
    if you have the CODEC(s) installed.
    -vhelp
  10. Okay, this is what I have done so far.
    1. deleted all codec, divx, etc... from my computer.
    2. I downloaded NiMo Codec Pack.
    3. Try opening the video with "windows media player 9.0" just like I do all others. I can see that its playing but I see no picture or sound.
    4. I use GShot to read the "DIVX CODEC VIDEO" and NOW it says that "GSHOT has found DIXV Decoder Filer, which is installed on your system, is a compatible with this format; based on that, the video for this should play fine"
    BUT the problem is that it does not work. I downloaded another video with DIVX CODEC VIDEO and it doesn't work.
    5. I search to find the CODEC that GShot say I have to make it work and it the XviD Codec. HHMMM
    6. Downloaded Vdub, and that doesn't work. Maybe I just don't know how to work Vdub?
    What im I doing wrong or not doing? I still can not view the DIVX CODEC VIDEO's.
    HHHHHHHHHHEEEEEEEEEEELLLLLLLLLPPPPPPPPPP!
  11. Banned
    Dec 2002
    Somewhere I belong
    Hmm strange,try this and see if it works:
    Uninstalled all DivX codecs and xvid codecs,(Nimo Pack etc.)
    You can then install xvid codecs from here:
    http://www.divx-digest.com/software/xvid.html
    Then install all DivX codecs separat (Not from Nimo).
    http://www.divx-digest.com/software/divxcodec.html
    After that install Nimo Pack but uncheck all divx codecs and the xvid codec and also uncheck a direct show filter which is Ffdshow DirectShow
    Install Nimo from here:
    http://www.divx-digest.com/software/nimo_pack.html
    Now all should work fine!
    By the way,AC3 comes with the Nimo Pack and I installed this with
    Nimo Pack Build 8,not the new Build 9
    I too had problems watching movies but then I installed all my codecs that way and not having any problems since then.
  12. crack_man, thx for trying to help me. I did everything you said. BUt no luck. This is what GSPOT is saying;
    "Format: DivX 5.0, 4CCX50
    GSpot has found FFdshow MPEG-4 Video Fecoder, which is installed on your system, is a compatible with this format; based on that, the video for this file should play fine.
    DirectShow is apparently able to play the file as well (see Directshow Render, below), though it has selected a different codec, the DivX Decoder Filer, whose primary 4CC (DIVX) does not match the file"s 4CC (DX50). This is because the codec claims to be able to decompress 14 others formats besides DIVX, and this format is number 5 on that list.
    This is usually not a problem, but under certain circumstances there may be a performance (quality) issue".
    I read english but I have no idea what this means? No sound no movie??
    WHAT CAN I DO?
  13. Member vhelp's Avatar
    Mar 2001
    New York
    morning jtquest,
    I still can't believe you are having probs w/ viewing your divX 5 clips.
    Perhaps you should send us (upload somewere's) a small sample of
    this "headacke" clip of yours ??
    IF you can't cut it to a small piece by using vdub, does anyone know of
    a suggestion on HOW to cut it. I have one, but will keep it to myself cause
    it's VERY complicated AND I don't know for sure that it will work. I rather
    not put jtquest though MORE headackes.
    Anyways, this way, maybe WE can open and view the clip and or view
    it's contents and help you better. Could just very well be that you PC
    setup is bad/fussy or clip is VOID.
    Please look into CUTting your clip for UPLOADING..
    -vhelp
  14. Banned
    Dec 2002
    Somewhere I belong
    I dont know if this works bu try use another player like zoomplayer and if that donīt work,try installing the new DivX 5.03.
