burnt fine nice quality
sounds good
use TMPGenc
and pravi dvd to burn
aspect ratio is 4:3 525
pixels are 352x240
the subtitles are cut off, like I can only see the top part of the subtitles
so I only see the top half of a sentence. Also it is slanted a bit to the right.
neone how to fix?
anyone??
I really need help
all my vcd's subtitles are cut off from the bottom
I think its either aspect ratio
or resolution?
not sure plz help -
I had the same problem but I managed to fix it, do a search for 'anime' & 'panasonic'
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
Weird problem importing son format subtitles from TS in DVDLab Pro
By Talayero in forum SubtitleReplies: 1Last Post: 15th Apr 2009, 05:47 -
DVP5982/37 subtitles weird experience
By brancaleone72 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jan 2008, 17:40 -
ahh! quick! help! convert files?!?!
By lebrnjmes23 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2008, 21:35 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30
