I was wondering if anyone have made a test using DVDit cDVD template it apears that using that it accept SVCD m2v and Mpgs.
I made one cDVD image on the hard drive and it worked ok
I had a lot of problem with the audio because first asked for 48K then after that it asked that the audio had to be made with the CRC option on TMPGenc.
After that i started inventing with AC3 at first it was ok but DVDit began to hang as if there was an incompatibility using AC3 file as a source.
I have a lot of SVCD that wouldnt like to reencode. Any Help?
SVCD2DVD
Results 1 to 1 of 1
First time opening my DVD pixma i4500 - is there a dvd template for printin
By netrate in forum MediaReplies: 5Last Post: 14th Nov 2011, 08:06 -
Converting a Final Cut Pro Motion template to a DVD Menu...
By Huntr777 in forum MacReplies: 0Last Post: 4th Apr 2010, 12:48 -
How to Create DVD Menu Template from existing DVD
By btodorov in forum Authoring (DVD)Replies: 3Last Post: 28th Jan 2009, 14:24 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
PowerProducer - edit dvd menu template
By kj1983 in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2008, 18:37
