  1. Hello.
    can annybody thel me wy y dont have sound on a movie burd on a cd
    with nero it's an mpg file and y wrote it like a video cd.
    please melp me thanks
    peter
  2. Hi try this...it worked for me...I was encoding to mpeg from divX and would get no sound when the mpeg file was finished..read a few posts and tried the solution.....at the top of TMPEGEnc click on Enviroment Setting and then into VFAPI plug-in ...once in there give Direct Show a higher priority
  3. Try to extract audio first in Vdub Full Processing. When you done you will have a WAV file, that WAV file point as Audio file in TMPEGEnc when encoding DiVX.
  4. As Tiras said....
    but also make sure that the coversion settings within audio in Virtualdub are:
    VCD Audio Specs
    16 bit
    44,100Khz sample rate
    stereo
    DVD Audio Specs
    16 bit
    48,000Khz sample rate
    stereo
