I used Raptor’s “idiots guide” together with doom9 dvd-9 to dvd-5 “ full copy” instruction (http://www.doom9.org/mpg/maestro2.htm) , using WinDVD s/w for playing “dvd from folder” it played perfectly on my p.c. ,with menus and every-thing ,but, when burning with Gear pro or Nero or Prassi Primo ( as DVD-ROM ) I could not play it on my stand alone dvd ( Toshiba SD220E ),It plays w/o any problems with my freand Greetz dvd.
Still,after burning dvd image from another DVD-R ( I do not know how it was authored ) I could play the dvd perfectly, so,it is not looks like a media problem.
Please help!!! which mode should I use with the abuve s/w
Tx.
Miki![]()
p.s. I used pioneer 104 for the burning process with Ritek x1 media
Hi!
I had a similar problem that i've posted... I have 2 DVD players, and the discs all worked with the Pioneer 717 and some didn't work with Panasonic RV-32. Finally i found that the Panasonic only read the discs made in UDF format! If a make a VIDEO disc or UDF/ISO it only works with Pioneer. Use a Re-Writable and test all formats! I'm sure you'll find the one.
Greetings,
Zaxxon
P.S.: I burn with Nero 5.5.9.17
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35
