Results 1 to 17 of 17
  1. Every time i try to convert xvid encoded avi´s i get a "ntdll.dll" error and sometimes a "out of source range" error what is wrong? Do i have a conflict in codecs or something? I have divx 3.11 alpha,divx 5,02,ffdshow,xvid,ac3 and the newest version of TMPGenc PRO.
    Dec 2002
    Blackpool, England
    yeah i get the same problem, I think its something to do with the xvid codec but if you click start again it should work. there is the other option which is converting it to some thing like divx and then convert it to mpg or something.
    Sord_Fish
    Inovate Don't imatate
  3. It only works sometimes,with the start again trick.. I know i could convert it,but it takes forever. Could it be i have an outdated xvid codec??
    Dec 2002
    Blackpool, England
    i think its because xvid isn't complete but i'm not 100% sure on that.
    wot is the spec on your computer
    Sord_Fish
  5. do you mean hardware??
    Dec 2002
    Blackpool, England
    yeah please
  7. AMD athlon 1200,512 mb ram,soltek sl-75kav mainboard,geforce 2 GTS,SB live,100 GB seagate,plexwriter and 52x cd-rom
    Dec 2002
    Blackpool, England
    well on that spec it shouldn't take that long to convert.
    if want to update your codec here's a site with them on.
    http://www.divx-digest.com/software/xvid.html
  9. It doens´t take that long to convert,and i have done it a million times,only this time i get this stupid error,and it pisses me off..I figured it was a codec problem,but it is still irritating..
    Dec 2002
    Blackpool, England
    where did u get the movie from may i ask
  11. Member Treebeard's Avatar
    Aug 2002
    try to increase the priority of directshow & avi reader in the environmental settings. then give it another go
  12. Member Treebeard's Avatar
    Aug 2002
    make directshow a 3 and avi reader 2 , everything else 0
    settings are in this guide
    http://www.vcdhelp.com/forum/userguides/119019.php
  13. Originally Posted by King-Of-DK
    How high??
    Make it +2
  14. ok,i will try that..What does it do? changing the priority
  15. Member Treebeard's Avatar
    Aug 2002
    changes the reading priority of the avi file and tmpgenc is able to read it better
