I've been trying to use Virtual Dub to capture an AVI. But I get an "No Capture Driver Available" error. I'm using an ATI AIW Radeon. I set the capture drivers according to the capture guide here. I did a search and found a suggestion to completely uninstall Virtual Dub and reinstall it. I did that twice, still no go. Does anyone have any other suggestions.
Seems like you are using WDM drivers. Look to http://www.iulab.com for iuVCR, it can capture just like VirtualDub but with WDM drivers.
Dmitri Doulepov
Software Designer
Microsoft Certified System Engineer -
Dmitri, need some advise from iuVCR users. I've been using virtualdub for capture and quite happy with it. Nonetheless I am trying out iuVCR. I find it okay as well. However I have certain things.
It can capture for an extended period (whether at 352x240 or higher resolution) but somehow after 40 minutes or so of capture it does not get to synchronize audio with video anymore.
Video was master stream when this happened. Tried using audio as master stream and the problem seemed to have gone away however the video became degraded in quality.
I am using a Flyvideo 98/FM card with a P4 1.5G, Asus P4TM motherboard, WIN2k with SP2 and the video capture update.
Any similar experience with iuVCR? If so how did you resolve it? Thanks in advance.
I have ATI Radeon64VIVO, AMD processor and AMD760 Motherboard.
I have MMC7.1., ATI DVD 4.1. and VirtualDub 1.4.7. installed.
For VFW support I used Win2K SP2 and Registry changes (for more information visit www.virgualdub.org/ -> News ->Old news -> ATI Installation).
VirtualDub with huffyuv 2.1.1. give me better results (video quality is just like a source) than MMC.
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56
