hi,
im using tmpgenc 2.59.47.155 and I am converting my vcds to be
able to be burnt on dvds.
Ive been following the directions on this url:
http://www.vcdhelp.com/vcddvdr.htm
and they work great.
my question is it possible to batch a bunch on the audio converions
(Step 2 - Convert the audio to 48 khz MPEG1 Layer2 or PCM or DD)
so that I could do like 10 and leave it over night instead of doing 1 at a time?
thanks for any help
Arthur
i'm sure you can batch the audio in TMPGEnc, but how about using BeSweet & its GUI (see tools page) to do this - then go back to TMPGEnc with your converted audio files later.
cheers,
mcdruid.
Audio Editor - Batch
By BobAchgill in forum AudioReplies: 2Last Post: 3rd Nov 2011, 07:43 -
Fast converion with customized menu ?
By Serville in forum Video ConversionReplies: 5Last Post: 15th May 2009, 22:04 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:00 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2009, 00:25 -
Normalize audio - batch possible?
By lj01 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2008, 20:19
