Looking through the forums this seems to be a common problem. With tmpgenc what is the difference between the source aspect ratios 16:9 display and 16:9 625 line (Pal) ? When should I choose one or the other ? I'm making vcd's for a pal tv system.
Cheers !
Hey, Chris. :P If the source file is a DivX, then the source aspect ratio would be 1:1 (VGA). If the source file was from a DVD, then it would be something like 4:3 625 Lines (PAL) or 16:9 625 Lines (PAL) depending on the aspect ratio of your DVD.
Hope That Helps!!!
:P
Thanks for the tip
. I'd been wondering about the 1:1 vga option. However, my source file is a dvd and I'd still like to know the difference between "display" and "625 line". I'm starting to get some good results after a lot of trial and effort ( and unwatchable vcd's) and I want to really get my configuration right.
Cheers ! -
Since your source file is from a DVD, I think you're supposed to select 16:9 625 line (PAL) if the aspect ratio of your DVD is 16:9. Try 16:9 625 line (PAL) and see if solves your problems!!! :P
Hope That Helps!!!
:P
@ 2573: stop posting short clips of crap. Please read the entire thread first!
Regards.Michael Tam
w: Morsels of Evidence -
well, the first post was :
well, the thing i wnat to replay is i dont use any of two ways, it is better use 1:1
It will be wrong or right, but it is my opinion.
Is this replay better moderator?
Display aspect ratios in MPEG-2
By DRP in forum EditingReplies: 4Last Post: 4th Jul 2010, 20:46 -
"display aspect ratio" changes by itself after remuxing .mkv vide
By roise_r in forum Video ConversionReplies: 5Last Post: 2nd Sep 2009, 02:35 -
Tool to change the Display aspect-ratio?
By cumi in forum Newbie / General discussionsReplies: 44Last Post: 4th Feb 2009, 09:25 -
Aspect Ratio: Pixel AR and Display AR
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 18:42 -
525-Line Widescreen Pixel Aspect Fraction
By Acid_Reign in forum Newbie / General discussionsReplies: 5Last Post: 4th Jun 2007, 17:15
