Ok here is all the details:
Movie: Minority Report Full Screen
Source: Dvd
Ok I Ripped the vob. files with Smart Ripper. Then I Created a d2v. file with DVD2AVI.
DVD2AVI settings:
Audio:
Track Number: 1
OutPut Method: Decode to Wav. (AC3,LPCM)
Dolby Digital Decode: Normal
48 -> 44.1khz: Normal
Video Information:
Forced Film: On
Information:
Video:
Aspect Ratio: 4:3
Frame Rate: 23.976
Frame Type: Progressive
Audio:
DD 3/2 448
After that I loaded the d2v. file into TMPGEnc. I used FitCd to get the correct CBR 2010 so that it will fit on 3 cd's.
Here Are the settings for TMPGEnc:
MPEG-2 480x480
23.976fps
CBR 2010kbps
Layer-2 48000Hz 224kbps
Source Range Enabled to make 3 seperate but equal parts.
I load the d2v file for my video source. Then I loaded the Wav. File from DVD2AVI as the audio ( AC3 T01 3_2ch 448Kbps 48KHz). I have made about 40 xvcd's before but this is my first time trying to create svcd's. Now I Run the program and it runs for a while then I get this
STREAM WRITING ERROR
I never had to deal with this and the only info you guys have on this error deals with bad frames in downloaded avi. files. Believe me I looked for over 2-3 hours total now. I am stumped I need some help. Thanks to anyone who can offer me some information on this because I get evrerything else to work fine but this error is a real pain.
I am wondering if it is a bad vob. file??? But the error never happens in the same place I was able to get the first 3rd to encode properly after 3 attempts. But now I have tried to get the 2nd and 3rd to go and they just wont fully encode.
Results 1 to 1 of 1
-=Triton=-
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 07:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 10:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 17:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 07:28
