  1. Ok, I am running Win XP Pro. This is the problem, my computer will auto play SVCD directly from the CD-ROM without a problem. I can play VCD files that have been copied onto the HD and renamed from .dat to .mpeg. The computer refuses to autoplay VCD's from the CD-ROM or play the .dat files that I manually select from the CD. I have tried updating to Win Media Player v.9, I have tried using PowerDVD, I have tried using WinDVD, I have tried downloading the ASPI driver or whatever it was called. I have looked through forum topics here also and didnt find anything useful. Oh and the VCD is a working one. I have tried 2 different movies now that I know work on a stand alone DVD player so the problem isn't with the discs. Any help would be much appreciated, thanks
    Oct 2002
    Helsinki
    With what equipment the VCDs were created to begin with?
    .a
  3. Used Nero 5.5.8.0 and burned with a TDK401248B.
    Oct 2002
    Helsinki
    This is a known bug in Nero on certain CD-Writers (check this forum for example).
    .a
